2005 Accord accessories/Radio turns on when car is off and key is out
Old Sep 26, 2019 | 02:00 PM
  #21
Hondapoolman's Avatar
It wasn't the ignition switch, It's an internal radio problem, Read post 19
Old Sep 26, 2019 | 06:14 PM
  #22
The ignition switch is an assembly where you insert the key to start the car. The electrical portion is removable, so you can replace if contacts get worn out. Look on youtube for people that replace the electrical portion of the ignition switch on accords. There are several videos out there on this topic for Hondas.
Old May 20, 2020 | 04:38 AM
  #23
Amod's Avatar
Smile PCB repair
I had similar problem.....took radio unit out of the dashboard....removed oxidation and re-soldered cold joints in PCB....and it is working well
Originally Posted by Hondapoolman
Hello, I'm new to the forum but looking for some help. I have a 2005 Honda Accord LX 2.4 AT and the radio and clock turn on overnight by itself and kills the battery over night. It seems/act as though the key is left on the accessory position of the ignition switch but the key is out when this happens. I thought it may have been the ignition switch, had it changed but but that wasn't the problem.
Is there a relay that turns on the accessory position of the ignition switch?
Thank you, poolman
OK, so I pulled out the radio and tested the yel/red wire for voltage with the radio removed. Didn't show any voltage at the yel/red wire with the car off and when the key turned to acc. it had voltage. Thus I'm pretty confident that it is the radio causing my problem. I put in a used radio and the problem seems to be fixed.
Is there somewhere I can send the original radio to be repaired? Thanks for all the help.
Originally Posted by theteri
I also have 2005 accord lx se with the same problem i also bought a used radio it did fine for maybe 3yrs now guess what i am having same problem again.radio plays and clock lights up w no key.honda says they have never heard of the problem but yet i called them 3yrs ago when i 1st started having the issuse the 1st time
Old Dec 28, 2024 | 05:44 PM
  #24
Gary W. Stoliby's Avatar
This generation is known to have issues with the stock head unit. Only real way to solve it is to use an aftermarket head unit, install a radio kill switch, or pull the radio fuse out when you get out of the car.
Old Jan 16, 2025 | 12:54 PM
  #25
ItsAlwaysSomething's Avatar
This has been an intermittent issue with this car which I bought in 2014. What might I expect to pay for a radio kill switch? Any idea? I am not a young person and have difficulty moving this body around into small spaces. :-)
Old Jan 16, 2025 | 05:38 PM
  #26
The easiest and cheapest way to get a kill switch is to determine the fuse you need to pull.
You can purchase a fused kill switch that plugs into the fuse. No splicing and plug and play. Search ebay with the line below to see what I'm talking about.
12"-100" Automotive Switched Fuse Switch For Mini 10A &15A Fuse WIth wire New
Just make sure you get the fuse adapter for the correct pin size. Im not sure if your accord uses mini or micro fuses.
You could also make this as well. It is a fuse connector where you put a fuse and a kill switch into the wire loop.
Old Jan 16, 2025 | 07:06 PM
  #27
Thank you so much for the reply. It is really helpful. I think a friend will come over tomorrow and take my battery and charge it. It would seem that we need to determine what the culprit is, though. He may have a multimeter. We'll see.
Neptun3
Oct 22, 2014 05:56 PM
csh217
Jun 17, 2014 05:53 PM
jlpatterson
Dec 9, 2013 06:25 PM
debby campbell
Jun 7, 2007 08:04 PM
