2005 Accord EX 2.4L I pulled the wires from the PCM sid of the O2 sensor connector.
Old Jan 16, 2021 | 07:32 PM
cinikal's Avatar
Default 2005 Accord EX 2.4L I pulled the wires from the PCM sid of the O2 sensor connector.
I pulled the wires out from the connector that goes to the O2 sensor. Can anyone help me with finding the wiring diagram from this area?
Old Jan 17, 2021 | 12:18 AM
I attached a picture of the connector. Your picture is upside-down compared to my attached picture, so make sure you are using the correct orientation on the connector relative to the release tab.
1 - Red/Yellow
2 - Red
3 - Green
4 - White/Black
Old Jan 17, 2021 | 12:24 AM
Seanjordan20's Avatar
Hope this helps
Attached Thumbnails 2005 Accord EX 2.4L I pulled the wires from the PCM sid of the O2 sensor connector.-photo18.jpg
Old Jan 17, 2021 | 10:28 AM
cinikal's Avatar
Thank you both for a quick response. Definitely solved my problem. So in my research I found this and wanted to add to the thread with a color diagram. Once again Thank you both!
johnv
Nov 12, 2019 10:32 PM
Violet1982
May 18, 2019 02:16 PM
Musicman81
May 31, 2015 06:57 AM
dogmarcopolo
Jan 25, 2013 07:22 AM
frankrentef
May 1, 2011 11:05 AM
