2005 Accord LX intermittent TCS ABS lights
Old Apr 16, 2024 | 12:06 PM
CraigDaliessio's Avatar
Default 2005 Accord LX intermittent TCS ABS lights
Did new passenger side drive axle, upper / lower control arms, ball joint, tie rod end. Since then, three separate occassions TCS/ABS light will come on and stay on until I stop, turn off the car and start it again. Can also feel the ABS "chatter" randomly from time to time. No OBD codes.
Old Apr 16, 2024 | 01:31 PM
Did you remove the ABS sensor when doing all of this work?
Can you scanner read the wheel speed reported at each sensor?
Old Apr 16, 2024 | 02:11 PM
I did remove the sensor to do the work. Locked it back down again. Maybe I need to recheck it.
Don't know if my scanner can read thjat. I will check
OhThreeVeeSix
Sep 25, 2009 02:12 PM
jdwilson4
Jan 8, 2009 09:14 PM
applejuic3
Jul 28, 2008 06:48 PM
dmoak
Jun 13, 2007 02:26 PM
Green_Accord
Apr 30, 2007 01:30 PM
