2005 Honda horn shorting problem
Old Apr 22, 2014 | 11:16 AM
jborg3's Avatar
Default 2005 Honda horn shorting problem
Whenever I blow the horn in my 2005 Honda 4-cyl EX the fuse blows, which kills the brake lights also. The horn does blow, so I don't think the short is there. Could it be in the steering wheel horn mechanism? Or the writing somewhere?
I tried to locate the horn relay but there doesn't seem to be one. Just the 20a fuse. Thanks in advance for any help.
Old Apr 22, 2014 | 11:17 AM
jborg3's Avatar
I meant to say "or the wiring somewhere"
Old Apr 22, 2014 | 04:49 PM
hardy1039's Avatar
I think you are assuming there is only one horn but in fact, there are 2 horns, a high and low horn behind the front grill. I guess if I were you I would disconnect both horns and hit the horn and hopefully the fuse will not blow. Then I would connect one horn at a time to find the culprit. Don't ask me how to get to the horn because I looked through my service manuals and I could not find the removal instructions. I think looking at my Accord, that you would have to remove the front grill. I could reach the horns through the grill but that was the extent of it...could not see the connectors. Good luck and let us know how you do.
BTW, the black 4" x 4" box to the right of the fuse/relay box is the Relay Control Module.
Old Apr 22, 2014 | 10:56 PM
jborg3's Avatar
I'll try that. Thanks.
yankmecrank
Aug 21, 2015 09:50 AM
Miss Frye
Jun 13, 2015 10:25 AM
archinut
Oct 30, 2010 02:56 PM
Jaeger
Oct 19, 2007 12:48 PM
chronchameleon
May 12, 2006 12:47 PM
