2006 4cyl suddenly using lots of oil
Old Feb 28, 2016 | 09:12 PM
oldbeek's Avatar
Default 2006 4cyl suddenly using lots of oil
My daughters 2006 4cyl auto accord has 175,000 miles of city/freeway driving. Last month when changing oil ,I found it 2 qts low at 7,000 miles on the oil. I did not investigate at that time. Now 5,000 miles later the oil light comes on and engine is 3 1/2 qts low. NO LEAKS! Tail pipe is carbon black. Power and driving is normal. Idle is perfect, and no ck engine light. I am thinking there is a vacuum valve malfunction that is allowing oil to be sucked into the intake. Where do I start? I am 50 years a diesel mechanic.
Old Feb 28, 2016 | 10:00 PM
With that much oil loss, the engine is leaking or burning oil.
You can check the pcv valve to see if it is clogged up.
You may also want to look at the usual suspects for oil leaks around the engine. Oil filter, oil pan bolt, oil pressure sensor, valve cover, look around the timing chain cover. You can add some dye with the oil and use a UV light after some time to try and locate a leak.
Old Feb 29, 2016 | 09:25 AM
Dr. Drivability's Avatar
Yup, pull the hose off the PCV valve and check for oil in it.
Here's the location.
Old Feb 29, 2016 | 03:25 PM
oldbeek's Avatar
AS s for leaks, NONE. I checked the intake air tubing and it is dry inside. There is a hose , top of valve cover, driver side going to a valve of some sort, right on the intake air tube. A little oil in this hose right at the valve cover. No oil where this all enters the intake air tube. PS: Air filter is clean.
Thanks Doc for the pic of PCV valve
Old Feb 29, 2016 | 04:22 PM
That hose to the intake is the other half of the PCV system. It's supposed to draw air from the airfilter, to make up for what is sucked out of the crankcase through the PCV valve. Having a little oil in there is kinda normal. A lot of oil in that hose is a sign of the PCV valve clogged up.
Old Feb 29, 2016 | 08:03 PM
oldbeek's Avatar
Changing the PVC valve and will watch to see if oil consumption stops. Thanks for all the replies.
Old Feb 29, 2016 | 11:32 PM
Make sure your daughter checks the oil level frequently and that she has some oil in the trunk to top off when needed.
I know on my old accord, I had a leaking pressure sending unit and it wasn't obvious that it was the source of my oil leak at the time.
spin05
Sep 23, 2021 07:10 AM
1accord1996
Apr 7, 2011 12:36 PM
Gordon
Nov 24, 2010 03:03 AM
elijahblake
Jul 21, 2010 07:31 PM
david314
Mar 17, 2007 12:00 PM
