2006 Accord LX-SE 4 Dr Air Conditioner Problem
Old Jun 22, 2020 | 08:45 PM
  #31
Seanjordan20's Avatar
With those numbers you should be blowing cold. 250 is not enough for me to say the expansion valve is bad.
So with the a/c on you jumped the switch and it turned on. I would then check to see if the switch is good. You've verified the relay is good and getting power down to the compressor.
Old Jun 22, 2020 | 09:00 PM
  #32
Michael Paecht's Avatar
No i ground the relay so it kicks the compressor on so the relay or pressure switch are not getting a ground which I believe comes from the pcm but it's a hybrid and I heard there was some compressor driver unit on a hybrid near the hybrid battery have you heard of that or a 30 amp fuse for the compressor driver?
Old Jun 22, 2020 | 10:00 PM
  #33
If you haven't checked yet:
Interior box
29 - clutch 7.5a
Engine bay
12- clutch relay 30a
R4- clutch relay
Those are the only fuses/relays on the hybrid that can affect the compressor operation
Attached Thumbnails 2006 Accord LX-SE 4 Dr Air Conditioner Problem-photo686.jpg
hondabonda
Jun 23, 2015 04:11 PM
Airdorn
May 5, 2013 12:21 AM
raybob
Jul 2, 2011 06:11 PM
richny
May 26, 2008 02:28 PM
holysmoke
Apr 25, 2008 12:23 PM
