2006 Honda Accord SE Oil Pan Removal - Not V6
Old Mar 10, 2015 | 05:59 PM
BMAN06ACCORD's Avatar
Default 2006 Honda Accord SE Oil Pan Removal - Not V6
I need a little here forum! I have followed the repair manual and I am stuck. I have all the bolts off and the oil pan off the engine, but it does not clear the frame to be remove all the way out. Am i missing something here?
Old Mar 10, 2015 | 06:25 PM
1. These are the service manual instructions, which are a lot more steps.
http://www.driveaccord.net/forums/at...5&d=1262963010
http://www.driveaccord.net/forums/at...6&d=1262963024
2. This other link refers to a mechanic's other way by removing the side engine mount, then use a jack and a block of wood under the pulley to raise the engine a little for the pan to clear.
http://www.justanswer.com/honda/3y0h...06-accord.html
Old Mar 10, 2015 | 06:29 PM
Turtlehead's Avatar
Usually by loosening the sub frame bolts (don't remove) and placing a jack and wooden block under the transmission to lift the engine/transmission you will get clearance to remove it.
ccookie66
Apr 12, 2019 04:43 PM
brianforr00001111
Sep 13, 2012 05:03 PM
frost506
Jan 16, 2012 07:21 PM
cruszczyk
Nov 14, 2011 08:06 AM
greg9442
Oct 15, 2009 10:37 AM
