2007 Honda Accord A/C & Heater quit working
Old Aug 15, 2014 | 02:54 PM
Turtlehead's Avatar
When the fan stops working try taking your fist and whack the blower motor. If it starts back up then it is usually a bad spot in the motor which would then need replacement. You can also try removing the motor and hot wire it to see if it works fine. If it does not then replace, if it does reinstall and check for loose connections.
Old Aug 15, 2014 | 03:38 PM
Blower fan motor can be easily tested in car by using a jumper wire, see thread:
https://www.hondaaccordforum.com/for...accords-59744/
Tony1M
Nov 6, 2023 08:29 PM
BSims66173
Nov 9, 2012 11:52 AM
Driver 1
May 25, 2011 11:33 PM
bglovept
Aug 25, 2010 07:50 PM
fuctcivic
Nov 17, 2006 03:34 AM
