2007 "rumble" when braking from speed
Old Apr 20, 2021 | 01:03 AM
Uncle Tupelo's Avatar
Default 2007 "rumble" when braking from speed
.....when i'm on the interstate, or on a long downhill and i step on the brakes i get a fairly loud "rumbling" noise.
no pedal pulse, no squeel, no bumping or clunking and it stops as soon as i release the brake pedal.
in town everything is normal and the brakes work fine, no noise.
i will check the rotor runout, but i'd think there would be pulsing at the pedal.
i'd think bad wheel bearings would always make noise.
maybe the axles/cv joints??
any ideas?
thanks
Old Apr 20, 2021 | 08:47 AM
Check whether the brake pads are worn down. I'd probably call that a "grinding" sound, but checking the pads is very easy if you're planning on checking the rotors.
What most people call "warped" rotors, is usually brake pad material unevenly transferred to the rotors, producing areas of the rotor that have different amounts of friction. But usually you feel that as the car shuddering when you apply the brakes.
Check all the suspension joints. Maybe a loose ball joint can cause this, and the reason you don't hear it around town is the braking forces are smaller.
Old Apr 20, 2021 | 01:14 PM
Thanks Jim, good idea - i will check those Akebono pads asap
Cheers
Old Apr 22, 2021 | 11:09 PM
Hi Jim, yes, i checked the runout & pads & balljoints today. Runout seems like 0mm (or close to that), balljoints stable, but pads about 1/16" or less.
And they only have 51,000 miles on them - HA! The wife was driving up to & DOWN from the local ski area almost daily this past winter
and that may have accelerated the wear, whatever. New Akebono pads are now ordered. I just have to assume when pads that thin get hot
they make noise/vibration, or - as you suggest - they may be more susceptible to the effect of build up on the rotors. We'll see, but it's got to be a good start.
Thanks! .
Old Apr 23, 2021 | 08:15 AM
Get the rotors resurfaced...?
The uneven transfer of pad material is sometimes visible as a different sheen or texture on the surface of the rotor. But sometimes it's subtle & difficult to see.
moey
Jul 29, 2020 01:01 PM
manbeing
Jun 2, 2014 11:06 AM
zedjr
Jan 14, 2013 01:25 PM
Cali94Accord
Jan 25, 2012 07:21 AM
maro
Aug 11, 2008 03:22 PM
