2008 Accord Outside Door Handle Removal
Old Jul 16, 2013 | 06:44 AM
moparmusclecars's Avatar
Default 2008 Accord Outside Door Handle Removal
I need advise! I know how to take the door panels off, the water shield, etc. I even know how to get the outside door handles off, and back on. I am just curious why it seems so hard to get the outer handle rod detached from the joint bushing. They seemed to be pressed in really hard, and I use a hook tool to remove them, but at times it lets the handle rock (spring area) and breaks the little center pivot plastic rivet head off which holds everything together. How do you get this rod off without hurting anything? I have yet to figure this one out. Does someone make a special tool? I have done quiet a few of them, and they are always a pain in the *ss to get off. Thanks guys!
Old Jul 16, 2013 | 10:10 PM
porkchop's Avatar
Try spraying them with a lubricant like PB Blaster. It has helped me in the past. It also helps in the reassembly of the clip/bushing.
darkgreen18290
Dec 5, 2013 09:27 AM
hhrumph
Mar 18, 2011 08:19 PM
tyjoja
Nov 22, 2008 10:47 PM
EkliptStudios
May 12, 2007 10:49 AM
iridebmx33
Sep 23, 2006 01:38 AM
