2014 Accord Battery replacement
Old Aug 1, 2017 | 04:25 PM
Tradewind's Avatar
Default 2014 Accord Battery replacement
2014 Accord EXL V-6, installed new battery and now my Daytime Running Lights no longer illuminate, the LED strip within each headlight assembly. Fuse is good. Could the problem be within the terminal assembly at the negative battery post?
Old Aug 2, 2017 | 05:29 PM
Inspect the work and be sure the cables are clean and tight. Then look through the owners manual at the fues listing and see if there is one or more that is tied to the DRL.
Old Aug 2, 2017 | 06:00 PM
Probably a blown under-hood fuse No. A8 (7.5A).
Old Aug 3, 2017 | 09:02 AM
Tradewind's Avatar
As mentioned in my first post the fuse was checked OK. The battery was properly installed.
Update.. after cycling the light switch through all positions twice the DRL now operate.
keep_hope_alive
Apr 1, 2017 12:38 AM
keep_hope_alive
DIY Answers.
May 11, 2016 09:02 PM
Cardsallday13
Jan 4, 2016 02:09 PM
cadams8221218
Jul 15, 2011 07:24 AM
RoKnAzn
Jan 19, 2007 01:56 PM
