2014 - Airbag light after Starter Replacement
Old Sep 12, 2022 | 05:12 PM
Raven65's Avatar
Default 2014 - Airbag light after Starter Replacement
So yesterday I disconnected the battery and replaced the starter on my 2014 Accord Coupe (manual) and today I noticed that my airbag light is on.
Are the wires that run near the starter related to the airbag system? Just wondering if I could have damaged something while wrestling with the starter.
How do I reset this light?
TIA
Old Sep 12, 2022 | 07:17 PM
rockhoundrob's Avatar
I am not familiar with air bag lights on Hondas.
But on some GM cars, if the air bag light comes on, it flashes a certain # of times depending on what the problem is, then stays on.
Does your light flash? If so, how many times?
If there is no flashing, I would be tempted to disconnect the battery for a few minutes, then re connect it.
And check the fuse for the air bags.
Old Sep 12, 2022 | 08:53 PM
Raven65's Avatar
Thanks for the reply. It doesn’t flash… just comes on and stays on. I’ll disconnect/reconnect the battery again and check the fuses. Maybe I’ll get lucky. There are a couple of wires that run down near the starter that I pulled on pretty good when trying to get the main power wire off of the starter and extract it. My fear is that they are related to the airbags and/or crash sensors and I’ve damaged them. I hope I’m wrong!
Old Sep 13, 2022 | 09:58 AM
Then the next thing is to look at those wire....
Maybe try connecting a Code scanner. Just because the engine light isn't on, doesn't mean there is no code.
kris_loehr
Sep 6, 2022 07:21 PM
Mxmeac
Feb 21, 2014 03:03 PM
libra2458
Apr 1, 2013 07:37 PM
niahuynh
Apr 27, 2009 07:27 PM
brittanym06
Aug 1, 2007 09:58 AM
