86 honda accord do hatchback problems please help!
I'm having problem with my 86 accord dx hatchback. My brake lights and my tails lights stopped working this morning at some point. I do know my turn signals and reverse lights work. I checked all the fuses and replaced them even if they didn't seam bad. My horn does work. I did check the brake light switch and the plunger is fine. I checked the bulbs and found a few that were bad or looked like and replaced those also. Still no lights. Please help.
That 20 amp "stop/horn" would be the one.
If you can, cheap volt meters can be had for less than ~$10 and can give better info than a test light and many do other things as well - continuity tests, ect.
So if the fuse is good and has been replaced my next suggestion is to test the brake light switch......this is where the test light/volt meter is needed.
WILLYS60
Jun 24, 2013 02:25 AM
dmanster1
Apr 8, 2013 08:11 PM
msm618
Jul 5, 2008 08:26 PM
