86 Honda Accord flooding
Old Sep 18, 2006 | 09:47 PM
8six3door
Default 86 Honda Accord flooding
86 Honda Accord seems to be flooding. Trying to restart engine after driving for 15 minutes or more is difficult. It smells of gas and will not fire (plugs are firing). If I let is set for about 15 minutes it starts will little or no hesitation. Does anyone know what this could be? The plugs are dry. It is a fuel injected engine.
Old Sep 18, 2006 | 09:56 PM
sir_nasty's Avatar
Default RE: 86 Honda Accord flooding
this sounds similar to what is going on with an 88 accord, you said it is getting spark and fuel? smells flooded but won't fire... I guess the first step would be determining if it's a spark or fuel related issue. Is your choke sticking? Once the car warms up try disconnecting the choke and see if it will start
Old Sep 19, 2006 | 04:33 AM
deserthonda's Avatar
ORIGINAL: 8six3door
chk the TW sensor .chk for codes ..ecu should be located under the driver's seat
Old Sep 21, 2006 | 11:28 PM
8six3door
I found that whenever it won't start that it IS NOT getting much fire. I only get the problem when the car is hot, or has been driven alot, and only when I try to restart it. Whenever it does start I get no problems out of it. No sputtering, no misfires, it just runs smooth. Maybe the Distributor?
Old Sep 22, 2006 | 03:51 AM
if it is a lack of spark issue ,, you might to test the ignitor or coil
huntersdl
Apr 5, 2014 02:27 PM
crashdummie
Nov 22, 2013 11:44 PM
jmitchell
Sep 20, 2011 05:57 PM
jaemin2
May 19, 2009 08:00 AM
DRJIV
Feb 10, 2007 12:11 AM
