86 LXI surging during decel
Old Jul 7, 2007 | 08:27 AM
rustyw
Default 86 LXI surging during decel
Hi,
I recently got an 86 Accord LXI, auto trans, 76k miles(it really was owned by a little old lady) that is exibiting odd surging of about 500 rpm (1200-1700) during deceleration. The surging is worse if the A/C is on but still there if it's off too.
As soon asI come to a stop and am idling at a standstill it stops the surging and idles around 1200 (seems highand when I put it in gear it "thunks").
The only KNOWN problem is an exhaust leak I haven't tracked down yet.
Some googling pointed to the Air Idle Control valve and/or the PCV valve. I removed the Air Idle Control valve and tested it in some boiling water. It seems to open and close fine but whether open or closed I can blow air through it and the very small orifice I couldn't get any air through. Not sure if this means anything or not. I couldn't find the PCV valve. (new to this whole honda thing! )
It doesn't seem to affect anything but performance seems a *bit* sluggish and I thought whatevers causing it might be hurting mileage. During a recent trip I got around 29-32 highway.
Any input would be appreciated.
Rusty
Old Jul 7, 2007 | 11:00 AM
sir_nasty's Avatar
Default RE: 86 LXI surging during decel
In our DIY section is a post called "Surging Idle" follow the link below...
https://www.hondaaccordforum.com/SUR...m_46125/tm.htm
Old Jul 7, 2007 | 01:14 PM
rustyw
I'd seen most of that info while googling. None of it mentioned surging specifically during deceleration so I thought that info would maybe narrow it down a bit. Will try the the fast idle valve next.
Many thanks!
Old Jul 7, 2007 | 01:36 PM
rustyw
possibly more pertinent info: the interior of the throttle body from the throttle plate back has a nice coating of oily soot.
highoctane
Dec 17, 2015 04:10 PM
merc1100sc
Apr 4, 2013 11:53 AM
hondahonda
Jul 5, 2007 01:32 PM
djarmysgt
Sep 5, 2006 11:44 PM
