87 Accord LXi No Start after Filling the Gas Tank
Old Jun 8, 2006 | 03:54 PM
compassltd
Default 87 Accord LXi No Start after Filling the Gas Tank
I have a 1987 Accord LXi which is fuel injected. The problem I have is that after you fill the car with gas it will not start right away. I have had to sit there for 1-5 minutes before it will start. Has anyone encountered this problem? Could it be the car going into vapor lock because something is clogged? Any help with this would be greatly appreciated.
Old Jun 8, 2006 | 06:48 PM
lightshow's Avatar
Default RE: 87 Accord LXi No Start after Filling the Gas Tank
does it only happen when the car is warm? if it does, then you might have a bad main relay. or, maybe your fuel pump itself is going out if the problem is that your not getting fuel. does the car crank and just not start?
Old Jun 8, 2006 | 08:06 PM
sir_nasty's Avatar
does it only happen if you COMPLETELY fill the tank or will it happen if you just add a gallon or two of fuel?
Old Jun 9, 2006 | 12:02 AM
compassltd
Hi, it does crank, but just won't start, acts like it is in vapor lock. after a minute or so it will just start right up... go figure
Old Jun 9, 2006 | 12:03 AM
compassltd
Hey Sir Nasty, no it does not have a problem with just a few gallons, it is only if I fill it up...
compiler
Oct 17, 2013 04:42 PM
Toddler00
Sep 14, 2012 08:10 AM
bjr001
Nov 25, 2010 12:05 AM
klhiggi
Sep 3, 2009 01:45 PM
adamc44
Jan 18, 2007 08:09 PM
