89 Accord LX 2bl codes
Old Nov 17, 2012 | 01:25 PM
chris_AM's Avatar
Default 89 Accord LX 2bl codes
Is there a way to get trouble codes from this car? I am having multiple issues with it and there is no check engine light or anything that I can see as far as diagnostics go. thank you for any help
Old Nov 18, 2012 | 07:01 AM
Wish there was......
I've played with a few of these and might be able to help.
Can you describe the issues and what has been done to the car and we can go from there.
Old Nov 20, 2012 | 01:50 AM
chris_AM's Avatar
Default One problem fixed more to go
Ok so I was able to fix a sputtering problem just by changing out bad plug wires and it fixed the main issue.
Now it is back to the original problem.
When starting from a stopped position in any gear it hesitates; if I just lay it on it hesitates less but I cant do that with a car in front of me so it isnt a leave it alone thing. It only does this at around 1000 to 1200 rpm and only when under load (in 2 and D3 and D4) not in neutral or park.
I know because I put the car in gear with brakes pressed and P-brake engaged and gassed it a little in each gear.
Heres the run down on my car:
The car currently has 233,248 miles on the engine, a newish tranny with about 75000 miles on it, new radiator, water pump, and hoses, belts are at around 2k miles, oil change about 2 weeks ago, original carb has been cleaned only with carb cleaner sprayed into it and has been removed and reinstalled twice (earlier post describes: https://www.hondaaccordforum.com/for...roblems-51025/), new fuel filters both of them, new spark plugs/wires, and a new battery.
Last edited by chris_AM; Nov 20, 2012 at 02:03 AM. Reason: additional information to add
Old Nov 20, 2012 | 07:54 PM
At a steady speed of ~45 mph, do you feel a "slight" miss in the engine when warm?
The #7 vac hose, saw that you replaced them (?) at the rear -firewall side of carb - can and will break....it is at the very base of the carb on the back side.
Are the rest of the tune up items up to date...cap, rotor, plugs?
Old Nov 20, 2012 | 09:09 PM
chris_AM's Avatar
Default Reply
I do have new plugs and wires but not new rotor or cap. I will try these things and update as soon as I install them. I also have not tried a steady pace ~45 and I will try that. I remember a slight hesitation up there somewhere but I was only looking at the rpm range not the speedometer so I will check that as well.
As for vacuum hose #7 I did replace it and I was careful not to damage it when I installed it however I will recheck that and do a vacuum test when I can.
Old Nov 20, 2012 | 09:45 PM
In the auto trans the #7 hose is hard to detect......in the manual trans it is easier as you have better contol over the rpm's (manual trans will fall "flat on its face ~1400 rpms under light acel....just about the time you'd expect the secondarie(s) to open, making you think a power valve or acel pump was bad)
...that being said. I was converting rpm's to MPH (for the auto).....so you are correct in watching rpm range vs mph.....
Chaos_THC
Apr 10, 2012 08:45 AM
pturnbul
May 3, 2007 02:30 PM
larrysnach
Mar 11, 2006 10:48 PM
megaman
Mar 10, 2006 01:13 AM
rcm800
Feb 17, 2006 02:56 PM
