89 LX-i throttle body
Old Jan 28, 2017 | 01:02 PM
Almost too funny....I just got done taking pic's of my 89 and was about to post them.....give me a minute to edit one of yours and I think you will see where the leak is coming from.
Old Jan 28, 2017 | 01:13 PM
Ok lets see how this goes.....in your pic I notice the coolant hose coming from the "front/intake" side of the TB looks like it is leaking - brownish residue on the hose and one pic it even looked wet.
Un-do the clamp holding the hoes to the TB, then wiggle the rubber boot and plastic part from the TB. Top the coolant in the rad, start the car and watch the area circled in blue and especially where the read arrow is and see if the coolant is coming from that hose.
I'm going to post this, then see what the pic's look like once I do....might have to edit some more on the pic's and or add more comments.
Attached Thumbnails 89 LX-i throttle body-3rd-gen-tb-pic-weeddogs.jpg   89 LX-i throttle body-3rd-gen-tb-pic.jpg   89 LX-i throttle body-3rd-gen-tb.jpg
Old Jan 28, 2017 | 01:21 PM
weedog's Avatar
what is that black part called.
Old Jan 28, 2017 | 01:30 PM
Ok, didn't come out too bad....the first pic is yours, I added a blue circle in the lower centerish around the coolant hose that looks to be the issue...the red arrow to what looks like a "wet spot" on the hose.
The second pic is from my son's 89 LXi, again the blue arrow is what I'm trying to show....last the third pic - from the service manual has a "black solid" arrow with a label of "coolant".
Again, top off the coolant. Remove the rubber boot from the TB (loosen the clamps) - you'll need to pull the hose from the PCV that connects close to the front of the TB as well. Start the car and watch that area closely.
Old Jan 28, 2017 | 01:36 PM
You posted this as I was typing. The "black part" is the Throttle Angle Sensor (aka Throttle Position Sensor = TPS). I don't know how else to say this so don't take this the wrong way - That "black part" IS NOT THE SOURCE OF COOLANT LEAKING. The TPS has no contact/interaction with the coolant on this car.
Old Jan 28, 2017 | 05:12 PM
weedog's Avatar
ok Thanks poorman212 and all the others that help me.it was the top small hose.Thanks Again
Old Jan 29, 2017 | 11:38 AM
  #17
Glad you got it......be sure top properly bleed the air from the cooling system.
Old Feb 5, 2017 | 07:47 AM
  #18
weedog's Avatar
poorman212 i have another ? for you. if you went to a parts store what hose would you tell them you need if you were me because they dont know what hose im talking about.Thanks again
Old Feb 5, 2017 | 09:16 AM
  #19
Now you are going to make me find an old paper book I have around here somewhere.....give me a few minutes to think where I put that thing.
Old Feb 5, 2017 | 09:45 AM
  #20
Easier than I thought.
Two ways to go about this. 19508-PK2-000 is the OE part number, in a parts store you are going to end up with a "somewhat" generic molded hose - in the old Gates Hose catalog I have it shows up as PN# 18020. I can scan the page in if needed.
That hose goes from the TB to the FITV.
Al_S
Jun 26, 2010 08:17 PM
myrtle71590
Jun 29, 2007 02:00 PM
accord4sroy
May 26, 2007 11:22 AM
mikel6690
May 9, 2007 02:45 PM
TedsF23accord
May 30, 2006 01:30 AM
