90 accord brake light problem
Old Jan 25, 2008 | 12:51 AM
dbro
Default 90 accord brake light problem
I have a 90 honda accord with brake light problems. Here's how it goes:
When headlights are OFF:
-when I brake, the two front corner marker lights come on (as if somehow wired directly into
the brake lights)
-"brake lamp" dash light is lit
When the headlights are ON:
-brake lights stay on all the time, whether I'm braking or not
-dash lights dim when I actaully am pressing the brake pedal
anybody have any suggestions? cuz I can't very well go around with my brake lights on at night all the time...
Old Jan 25, 2008 | 08:27 AM
Default RE: 90 accord brake light problem
Check for a bad ground at therear lampclusters.
Then check for an un-wanted connection between brake & taillight circuits at the rear lamp clusters. This can also be caused by bulbs being installed wrong.
The combination brake/tail lamp bulbs actually have 2 filaments, & they have 2 little contact nubs at thier base. They're only supposed to go in the socket one way, but they can be forced in backwards to cause this problem. Or... a single-filament bulb was installed where it should be a 2-filament bulb.
Or... one time I saw the 2 little contact nubs at the base of a bulb had been mashed so the contacts inside the bulb socket would touch both nubs together.
WindPhoenix
Aug 10, 2012 10:15 PM
DannyJdm
Mar 28, 2012 08:03 AM
victorywhity
Mar 24, 2011 09:37 PM
98accord98
Sep 8, 2006 01:25 AM
