'91 Accord LX auto
Old Oct 29, 2013 | 08:26 AM
nigel's Avatar
Default '91 auto not shifting
Another observation that just came to mind.
After I cleaned and reinstalled the VSS, I cleared the computer by removing the negative battery terminal and as soon as I start the car the "S" light is on. Every time I reset the computer. No movement or shifting. As always the "Check Eng Light" is out and doesn't come on until I drive it a bit and then it illuminates and throws a 17 code, VSS.
I did order a new VSS from the internet and it should be here thurs or fri.
If it isn't the VSS then the only thing I can figure it's the Auto Trans Computer.
I've cleaned and/or repaired everything else.
Thoughts?
Update; Wed, still waiting on the new VSS.
Cheers
nigel
Old Oct 30, 2013 | 06:01 PM
Get the VSS installed and lets go from there.
Old Oct 31, 2013 | 09:07 AM
nigel's Avatar
Default '91 shift problem
Will do.
Thanks.
Cheers
nigel
Old Nov 2, 2013 | 12:28 PM
nigel's Avatar
Default '91 Accord won;'t shift
Installed new, aftermarket VSS and all is back to normal after cleaning and reinstalling the old one. Must of had a bad pick up internal.
Re soldered the Main Relay and the won't start when hot without waiting problem solved as well.
Thanks for the help.
SEE POST 16 and 17, it screwed up again!
Cheers
nigel
Old Nov 2, 2013 | 12:37 PM
Nice to hear
Old Nov 2, 2013 | 04:39 PM
nigel's Avatar
Default '91 Accord shift problem, still !!
So, after an extended test drive at normal and fast, stop to curise cycles I parked the car for my friend and called it quits.
Three or so hrs. later went for some food and after 5 minutes or so, (several stop and starts for stop signs) the transmission down shifted from fourth to 2nd, (while in motion) and at the same time the "S" light came on.
Came to a stop light, stopped, turned left and a block or so later the "S" light went out and it started to shift again while in motion.
No "Check Engine Light" at all during this "S" light return.
Haven't shorted the code connector to check for stored code.
Went to drive up, ordered and went back to her house after one short side trip.
The light stayed off the rest of the time and didn't come on again. Shifted as normal.
W T F ?????????
I'm so sick of this .......
Cheers
nigel
Old Nov 2, 2013 | 05:28 PM
  #17
nigel's Avatar
Default More
Just tried to pull the codes if any, as there was no Check Engine Light, and nothing, no codes or flashing lights!
When I shorted the blue plug to read "Check Engine Light" flashes, the light was on but stayed on and no flashing. No "S" light.
Pulled the shorting wire from the connector and no Check Engine Light or "S" light.
Went for another test drive and couldn't repeat "S" light illumination and thus no shift problem as before on food run.
Did push the "Sport" button on the shift stalk and it worked as advertised.
Cheers
nigel
Old Nov 2, 2013 | 05:53 PM
  #18
Mytman's Avatar
sorry for my ignorance... but how do i post new thread? Please help
Old Nov 2, 2013 | 06:58 PM
  #19
nigel's Avatar
Default New thread
Click "General Tech Help" on home screen and on the very top, left side click "New thread".
Cheers
nigel
Old Nov 3, 2013 | 07:07 AM
  #20
So when you jumped it the S or D4 on the dash did not flash any codes? If this happens again, don't turn the car off - check for codes.
Did the speedo act up at all when this happened?
