91 Accord problem
Old Sep 21, 2009 | 05:26 PM
hondarider753's Avatar
Default 91 Accord problem
my tach started to jump around at first for awhile and the car would miss and barely run then sometimes it would run fine but now it does it all the time... ill start it up it will miss for a min then just die... sometimes it wont even start but when u turn it over the tach goes crazyy i replaced the entire distributor with new ICM coil plugs wires cap rotor but it still does it.... any ideas? thanks alot
Old Sep 22, 2009 | 11:38 AM
hondadude's Avatar
internal coil? or stand off coil? EX, LX, DX
Power from the ignition switch w/key on at the Black/yellow wire at the dist. plug?
Old Sep 22, 2009 | 12:47 PM
internal coil which is new and yeah theres battery voltage at the blk/yel wire with the key on.
thanks for any helpp
Old Sep 22, 2009 | 03:51 PM
There is a grounding point for the wire harness that attaches on the thermostat housing (I think).
You may want to lightly sand the contact and make sure that the bolt is on tight.
Old Sep 23, 2009 | 02:09 PM
well thanks for all the help guys but i think i found the problem it blew the head gasket the oil is full of water and im thinking the lack of compression is causing my problems with how it runs? should i replace it or junk it? it has 260000 miles thanks
trouble
Aug 21, 2012 07:46 PM
jkrueger2020
Mar 10, 2011 02:18 AM
kellysa111
May 1, 2009 08:35 AM
mahones
Oct 13, 2008 08:24 AM
92Inspire
Aug 13, 2006 03:37 PM
