91 Accord Speedo/Trans Problems
Old May 14, 2011 | 10:12 PM
ryandavis33's Avatar
Exclamation 91 Accord Speedo/Trans Problems
Hello all!!
I have a 91 Accord EX Auto Trans
Every now and then i will be driving and the speedometer(i just replaced from a 92) will drop to zero and the "S" light will blink. after about a minute the spedometer came back on but the "S" light was still flishing. When i came to a stop the car seemed to idle lower than nomal.
When i got home i puled into the drive way and opened the hood while it was idling low. I pushed on the little lever on the intake and reved it. the car reved and then when it came back down it almost died but recovered. I did this 2 times.
I shut the car off and restarted it. Everything is fine.
Please, i would LOVE to hear some input!
Old May 14, 2011 | 10:20 PM
The S light flashing means the transmission computer detected a problem. Did the check engine light (engine computer detecting a problem) turn on as well?
Regardless, you should check for engine and transmission codes. It is very simple to do. Read the thread called How to check CEL codes in the DIY section. Count the check engine light and the S light for codes. Let us know what you find, then you can narrow down the problem. Also tell us which light flashed each code.
Old May 14, 2011 | 10:35 PM
OK i will do that
BTW the Check Engine light is burnt out
Old May 14, 2011 | 10:41 PM
You should probably fix the check engine light bulb.
I think that the 91 accord had a window on the engine computer (ECU) that you can look at a LED flash the codes using the method in the DIY section. You may not even have to short the connector.
The transmission computer (TCU) has a LED as well. They are located on the passenger foot well near the firewall. You will have to pull back the carpet to see the ECU and TCU. They are right next to each other.
Old May 15, 2011 | 03:18 PM
Cool
Can you send me a link mate? i cant find where to look anywhere on the DIY area. Thanks! and Cheers!
Old May 15, 2011 | 04:20 PM
Idle4evR
Jan 14, 2012 05:33 PM
highside18z
May 14, 2011 04:52 PM
guru350
Feb 3, 2011 02:10 PM
1990 accord
Jan 29, 2007 02:28 AM
PJ_STYLES_95AccordEx
Aug 21, 2006 11:45 PM
