96 accord speedo problems
Old May 8, 2011 | 10:50 PM
highside18z's Avatar
Default 96 accord speedo problems
Hello, I am new to this site so I hope I am doing this right. I just bought a 96 accord and the guy i bought it from said the speedo just quick working, like it was at 30-40 miles an hour then it just kept going all the way around, now it just kinda hangs down at the bottom and it fluctuates just alilttle against the pin at zero. the odometor still works just the speedometer does not, if any ideas i can try would be really helpfull, and if it is one of the speed sencers where can i find them. thanks Steve
Old May 9, 2011 | 10:03 AM
Does the cruise control work when the speedometer is not working? Stop by a parts store and have them scan for error codes. You connector is behind the ash tray.
Old May 12, 2011 | 10:20 PM
Thanks for the reply, and yes the cruise control and the odometer and the trip odometer all work, the speedometer needle is at the bottom of the gauge untill I start moving then it hits the back side of the little pin at zero then back the the bottom when I stop. I just bought the car so there was no code to read I even put the obd2 on it with no results, so I am hoping the longer I drive it I am hoping the code comes back on not to sure about that though
Old May 14, 2011 | 01:39 AM
1hgcd5's Avatar
check electronics for the transmission,? thats what i had problems with went to the local shop they changed out some wires going to the transmission that fixed it for good.
Old May 14, 2011 | 04:52 PM
Default 96 speedo problems
Idle4evR
Jan 14, 2012 05:33 PM
ryandavis33
May 15, 2011 04:20 PM
guru350
Feb 3, 2011 02:10 PM
1990 accord
Jan 29, 2007 02:28 AM
PJ_STYLES_95AccordEx
Aug 21, 2006 11:45 PM
