91 clutch problem
Old May 3, 2008 | 10:10 AM
vanishs13
Default 91 clutch problem
hey im stuck on what the problem could be, my clutch pedal is going soft and I cant put it into gear.
The MC was replaced over a month ago, checked under the dash, no ooze nor was there fluid around the actual MC. Checked the clutch resevoir, its full to the top. I checked the slave, no fluid outside or inside the boot.
so yea, im stumped, any ideas?
Old May 3, 2008 | 11:02 AM
sir_nasty's Avatar
Default RE: 91 clutch problem
It sounds like an adjustment issue. If the fluids full (with the proper fluid...) and it's not leaking anywhere then you may just need to adjust it. Unfortunatly I don't recall how to do it off the top of my head, go to our DIY section and click on the free manuals and download one for your car and it should have the procedure in there....
vetski179
Feb 24, 2015 04:26 PM
jkrueger2020
Mar 10, 2011 02:18 AM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
