92 Accord Coolant problem
Old Jun 15, 2013 | 03:48 PM
Kyleholland's Avatar
Exclamation 92 Accord Coolant problem
I have an 92 Honda Accord SOHC and was having issues with it trying to over heat when ever I came to a stop or drove at low RPM, if I cranked the heater after a min the temp would go down. So I replaced the thermostat to start off with, for a couple days it was working great, but now it is over heating even while driving, I have to be at high RPMs to get the temp down the heater trick doesn't even work any more. I am a little stuck, I am not sure what it going on and I don't have the money to just start replacing everything. Any help/ideas would be awesome. Thanks ^_^
Old Jun 15, 2013 | 07:55 PM
Are cooling fans running when engine temp is high? If not, you may have bad cooling fans, relays, or thermoswitch A (turns on fans when temp reaches 194F, about midpoint on gauge).
ghostgxz
Jan 18, 2013 01:50 AM
beastyme
Oct 19, 2012 05:01 AM
AkbarGr8
Sep 8, 2010 06:28 PM
bgtcket5
Aug 9, 2007 05:48 PM
lm_dicp
Feb 19, 2007 11:03 AM
