92 Accord Lx 2.2 Fuel leak
Old Sep 8, 2013 | 04:46 PM
Revmedwn75's Avatar
Default 92 Accord Lx 2.2 Fuel leak
I replaced the Fuel Filter and gas is spraying out of the feed line. I removed it and installed it 3 times. I can move the line in and out about a 1/4 in. and the nut is all the way tightened. Fuel line does not seem bent and nut is not cross threaded. What am I doing wrong?
Old Sep 8, 2013 | 05:01 PM
How does the flare on the fuel pipe look?
Old Sep 8, 2013 | 06:40 PM
Revmedwn75's Avatar
Default 92 accord Lx 2.2
The Flare looks ok. Why is the fuel line moving? Should tighten with the bolt right?
Old Sep 9, 2013 | 09:13 AM
Suggest re-installing old fuel filter and see if leak is fixed. If yes, you may have a mis-machined fuel filter where flare of tubing seats. Fuel filter is something easy to do on this model, so gets frequently done but filter rarely causes a problem. You might just live w/ old filter if leak stops.
Fuel filter is practically non-serviceable on 94-97 Accords (my 94EX is original at 247K miles and almost 20 yrs service), and service is not a routine maintenance requirement.
Old Sep 9, 2013 | 07:43 PM
Revmedwn75's Avatar
Default 92 Accord Lx 2.2 Fuel Leak *UPDATE*
I did re-install the old filter and it stopped leaking! I had purchased an after market FF, there was a lip at the end where the Nut/bolt was stopping, causing the issue. OEM is the way to go....Lesson learned. Thanks everyone.
Honda Enthusiast
Feb 15, 2011 08:43 PM
Johnene
Aug 24, 2010 06:59 AM
v-tec23
Aug 14, 2010 08:43 AM
EBK142
Jul 20, 2009 09:10 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
