92 accord quit
Old May 2, 2012 | 08:40 AM
mdg's Avatar
mdg
Default 92 accord quit
92 accord, automatic, was stalling but pumping gas pedal restarted it, thought it wasexaust system replaced cat, resonator,all pipes and muffler....
test drive wnt bad car died, the tach droped to zero ....
has newer cap, roter, igniter, wires, plugs, egr, coil, main relay,fuel filter...
posibly lost the igniter again????
Old May 2, 2012 | 09:02 AM
Does it die while the car is moving? Or when you come to a stop? Trying to determine if its an idle problem or another problem.
Old May 2, 2012 | 11:39 AM
mdg's Avatar
mdg
It dies driving or idling, like turning key off, doesn't sputter but if you pump gas pedal it will pop and start again with a back fire, I just noticed the air intake tube was loose at carb.. pulled it off and the in side of the unit is black both sides of the butterfly...
Tony1M
Nov 6, 2023 08:29 PM
indianbullet
Jul 8, 2012 09:48 PM
bglovept
Aug 25, 2010 07:50 PM
pfrathjr
Mar 14, 2008 03:50 PM
graydw1
Sep 13, 2007 11:26 AM
