92 accord shift solenoid A questions
It is outside of the transmission. You would just have to remove 2 bolts and unplug it to remove it. A junkyard would be the cheapest place to find one.
#5 is the shift solenoid A + B (it is one unit).
The solenoid unit you have to replace has both shift solenoid A and B. You can't replace just A.
If you have a volt meter, you can unplug the connector. Test the resistance to ground (valve cover bolt works) on each pin. The resistance on both of them should be 12-24 ohms.
You can also unbolt the solenoid and clean the solenoid and the screen in the gasket with throttle body cleaner. If crud builds up in there, it could clog the solenoid and not let it work properly. I am not sure if that would trip the D4 light, but it is worth a shot.
swingkid50
May 20, 2012 09:29 PM
