92 Honda Accord LX Steering Problem
Old Apr 3, 2013 | 06:24 PM
Sefa Fisaga-Aulaumea's Avatar
Lightbulb 92 Honda Accord LX Steering Problem
Hello, I'm new to the forum and wanted to see if I can get some help/advice and the problems I'm having with my Accord.....
Problems:
- Steering is very rough and makes noise when barely turning the wheel.
- Installed a new alternator and found out the "adjustment bolt" was missing which causes a squeaky annoying noise while driving. Where can I get a bolt from?
Any help/advice is appreciated, thank you.
Old Apr 3, 2013 | 07:32 PM
Has any work been done on the PS system recently? Can you describe the noise, I know that is hard to to in words.
Not sure which bolt is broke? Got a pic.EDIT: Or see if this helps in "which bolt"...sorru forgot I even had this.
Attached Thumbnails 92 Honda Accord LX Steering Problem-4th-gen-alt-tension.jpg
Old Apr 3, 2013 | 08:52 PM
I did purchase the car a few months ago, was told that timing belt, power steering was replaced, also the cv joints, as for the noise when I make a slight turn it sounds like a it's struggling to turn.
As for bolt it's the one the red arrow is pointing at.
Old Apr 4, 2013 | 08:08 PM
You can get the bolt from the dealer or find and "aftermarket" version. Just know that bolt "threads" into the lower alt bolt, so you want to be sure it didn't break off in there.
Old Apr 5, 2013 | 05:15 AM
BlindGungfu's Avatar
If u have a junkyard nearby u can grab bolts, I live close to a pick n pull. Usually dont get charged for a bolt or two.
For PS, have u checked fluid? If u lucky. A lot of people use atf, but I use the Honda fluid. Its like 6 bucks a quart at orielly
amajakgar
Aug 9, 2014 09:22 AM
loki16
Aug 12, 2013 06:54 AM
Enormus
Jul 31, 2013 10:01 PM
darkgreen18290
Jun 25, 2013 07:51 AM
