92 transmission problem
Old Dec 20, 2008 | 12:18 PM
cbinva's Avatar
Default 92 transmission problem
Hello I am having a problem with my 92 accord automatic transmission.When I come to a stop and restart the transmission does not engage right away seems like its slipping.As this is happening the D4 light flashes once.Also when I shift into reverse the D4 light comes on also and stays on.Other than those two problems the car runs fine.I already drained and changed the tranny fluid and saw nothing out of the ordinary the fluid looked fine just a little darker than the new stuff.Does anyone have any suggestions as to how to fix this problem?Thanks in advance for any help you can give me.
Old Dec 20, 2008 | 01:02 PM
Default RE: 92 transmission problem
Check the Trans Control Unit (TCU) for codes by shorting the service check connector under the dash, beneath the glove box. When keyswitch is turned to ON, the D4 light will flash the codes. Long flash =10's digit and short flash = unit's digit. See DIY section for details. The code/s will provide best clue to nature of yourproblem.
Old Dec 20, 2008 | 02:08 PM
cbinva's Avatar
Thanks when I short the circuit the only thing that happens is the check engine light comes on no flashes from that or the D4 light
Old Dec 20, 2008 | 03:37 PM
If you haven't tried, remove BackUp Fuse in underhood fuse box for 20 secs to reset the ECU and see if any codes appear afterwards or improvement in symptoms.
Does the CEL come on for two secs and go off when keyswitch is first turned to ON? If not, ECU malfunction is indicated.
Old Dec 20, 2008 | 04:17 PM
cbinva's Avatar
Thanks TexasHonda I will try the fuse but I do know the cel light goes on and then goes off like it should any other suggestions would be greatly appreciated thanks again.D4 light flashes after I come to a complete stop and start again
Old Dec 21, 2008 | 12:40 AM
You might have to count the flashes on the TCU itself. I do not remember when the accords started having the D4 light flash.
Make sure that you actually shorted the service connector.
Old Dec 21, 2008 | 01:08 PM
cbinva's Avatar
Reset the ecu and am still having the same problems.If I take the cover off where the ecu and the tcu are located under the glovebox will I be able to see the flashes?
Old Dec 21, 2008 | 02:37 PM
You should be able to use D4 or Sport Light in instrument panel(sport shift button on auto shift lever) flashes to read TCU. Not sure when sport light was discontinued, but was present on 90 Accords.
You can also pull carpet back and read the LED flashes. On 90 Accord, the LED lens is right of center in the ECU/TCU module beneath pax side carpet.
trouble
Aug 21, 2012 07:46 PM
MessAround
Aug 13, 2011 09:45 AM
mamarotta
Nov 13, 2010 11:10 AM
kellysa111
May 1, 2009 08:35 AM
Krashnpa
Jan 15, 2006 12:57 PM
