93 accord se. Starting problems
Old Jun 16, 2015 | 09:23 AM
ez55zman's Avatar
Default 93 accord se. Starting problems
Hi I am new to this but my 93 Accord will turn over and not start sometimes and then start and runs fine. When it is doing this the Park and Overdrive lights are on . I have changed the Neutral Safety Switch. I am stumped thanks .
93 Accord 2.2 SE AT
Old Jun 16, 2015 | 09:54 AM
ez55zman's Avatar
Default 93 Accord 2.2 SE AT
93 Accord 2.2 SE AT
Old Jun 16, 2015 | 12:49 PM
When no-start occurs check whether spark is being generated, or not.
Spray 5-10 secs of throttle body cleaner into intake duct behind intake air filter. Attempt to start.
If engine starts and runs briefly, spark is OK and fuel delivery is the problem, Main Fuel Relay or Fuel Pump are likely causes.
If engine still does not start, spark is not generated. Either distributor fault or ignition switch assy faults are likely.
Post your results for further guidance.
MRMASON
Oct 3, 2006 07:15 PM
masteve69
Aug 20, 2006 04:58 PM
applewart
Aug 9, 2006 03:07 AM
hofmeister
May 26, 2006 09:11 AM
KimberlyC
Apr 16, 2006 11:51 AM
