93 lx stock motor swap question
Old Apr 20, 2012 | 04:31 AM
buhhda05's Avatar
Default 93 lx stock motor swap question
I have a 93 lx with a h22 a1 non vtec. I have found a h22b1 vtec complete with tranny, ecu, and harness for my car. Should this be a straight pull the old one out and put the new one in swap? Or are there some major issues i need to address? One of my concerns is the motor and tranny mounts, seeing how both are h series motors, they should be the same right?
Old Apr 20, 2012 | 07:43 AM
Well I'm a little confused, I think you meant you have an f22a1, and found a f22b1.
How easy it is to swap in will depend on what year the f22b1 is. If its 94 or 95 it will be a whole lot easier than 96 or 97.
Old Apr 21, 2012 | 10:13 AM
buhhda05's Avatar
I will say that it is from the older years per say........will the mounts still be the same? I am on a limited budget at the moment, and i believe 400 bucks for the whole swap is pretty cheap, but, i dont want to get it and then have my dd down for two weeks waiting on parts and such.
Old Apr 21, 2012 | 11:28 AM
crispin's Avatar
What are you saying? Are you talking in riddles?
live2rice asked you what motor you have is it an F series or H series and you answer with "I will say it is from the older years per say..."
This isn't some big secret you have to keep.
It is simple, what motor do you currently have and what motor are you putting on?
Also if you car is currently running (as you say it is your daily driver) why are you changing the motor in first place per say???
So some straight answers from you will make it easier for us to give you some straight answers per say...
Old Apr 22, 2012 | 07:18 AM
buhhda05's Avatar
What i meant was that the motor im putting in would be from 94 or 95 not 96 or 97 like he stated in his post. Hence the "older years per say". Im am unsure as to what the motor exactly came out of. I just took a guesstimate. As for the reason for the swap, part of my love for Honda's is vtec. The motor i have is non vtec, and the motor i found is a vtec. The person that has it, want to sell everything, not just peice it out, or else i would just ask for the head. Also, my tranny hace a 3rd gear issue that needs attention, and seeing how both motors are f series, the parts should be interchangeable.
Old Apr 22, 2012 | 07:32 AM
crispin's Avatar
so it is an F series vtec or an H series vtec? - those are 2 different motors.
H series Vtec is for producing more power the F series vtec is for better gas mileage.
If you are swapping in a F series vtec you WILL NOT have a faster car.
Old Apr 22, 2012 | 07:38 AM
crispin's Avatar
here are the details on the motor. Now many guys know more about the swap then I do so hopefully they will chime in and correct me if I have something wrong.
F22B1
This engine was used in the 1994-1997 Honda Accord EX and the 1997 Acura CL. It was the first F-series engine to feature VTEC. The VTEC on this engine was tuned more for fuel efficiency than performance. Specifications
Bore × Stroke: 85.0 × 95.0 mm
Displacement: 2156 cc
Compression ratio: 8.8:1
Valve Configuration: SOHC, 16 valves (4 valves per cylinder), VTEC
Max power: 145 hp (108 kW) @ 5500 rpm
Max torque: 147 lb·ft (199 N m) @ 4500 rpm
VTEC Switchover: 2600-5250 rpm (2-stage variable)
Redline: 6200 rpm
Rev limit: 6500 rpm
Firing order: 1-3-4-2
Fuel control: (1994–1995) OBD-I (1996–1998) OBD-II PGM-FI
Old Apr 22, 2012 | 09:20 PM
buhhda05's Avatar
How do I tell the difference between the two? That is something that i have no clue about. I have always though that an "f" series was for example " f22" and a "h" series was an "h22".... I appreciate the engine specs crispin, seeing how you have helped me in the past, I am all ears to what u have to say.
Old Apr 22, 2012 | 10:12 PM
crispin's Avatar
it is stamped on the block on the front towards the transmission side.
I can take a pic tomorrow if you want.
If your transmission is bad I can understand replacing it but it is way too much work (ecu, new wiring) to just put a F series V - tec in your car.
Old Apr 23, 2012 | 04:53 AM
buhhda05's Avatar
The pic would be appreciated, i will also have to take a look at my block as well. It simply seemed like a "cheap" fix at the time, as well as a little more horses at the same time. Thanks for all the info crispin!
Woodall
Mar 4, 2014 04:21 AM
ruff12306
Dec 20, 2010 03:56 PM
mrbaysick
Sep 25, 2008 04:53 PM
brennonm
Sep 1, 2008 10:42 AM
accord4sroy
Aug 22, 2007 11:24 AM
