93 oil cooler oring replacement
Old Feb 2, 2007 | 12:12 AM
collierville's Avatar
Default 93 oil cooler oring replacement
CAN YOU GIVE ME ADVICE ON HOW TO CHANGE THE O-RING BEHIND THE OIL COOLER ON A 1993 ACCORD EX. IT IS LEAKING (195K) ( I CLEANED OFF THE FILETER NO LEAK THERE) 1. WRENCH SIZE
2. DO I NEED TO DRAIN THE COOLANT OR WILL THE O-RING SLIDE UNDER BOLT.
3. ANY TIPS ON R/R
4. DOES A LEAK MEAN THAT ITS AN O-RING OR COULD THE OIL COOLER BE BAD.
THANKS , KEN
Old Feb 2, 2007 | 01:01 AM
hondadude's Avatar
Default RE: 93 oil cooler oring replacement
yThe 'O' ring under that intercooler is a known leak point. P/N 91316-PT6-003 About $3
I'll bet it is rock hard.
I think it is a 30mm nut on the oilcooler center bolt, been a long time.
You don't need to take off the coolant lines from the intercooler.
Heres a little trick for ya, clean the block threads with some brake clean and the block end of the center bolt, use locktite on those threads.
What I've seen happen is an over tight oil filter will cause that center bolt to back out of the block.
[IMG]local://upfiles/5417/CDABFF385FDA43948E1A00BE2263E41E.gif[/IMG]
Old Feb 2, 2007 | 01:26 AM
Thank You for the p/n and tips. Hope the dealer has o-ring in stock here in memphis.... Ken
Old Feb 2, 2007 | 01:29 AM
I just found that picture on majestic honda site..
http://www.hondaautomotiveparts.com/...P-OIL+STRAINER
Old Feb 3, 2007 | 10:57 AM
Hondadude,
Thx's for the help. It was a 30mm socket. There was plenty of room to get to the o-ring the oil cooler moved right out of the way. Took about an hour total time. Were up and running agin . Ken
LambertJohn
Sep 3, 2010 01:16 PM
Pickrng
Jun 22, 2010 04:32 PM
Big Tex
Sep 8, 2008 09:42 AM
fryhead
Feb 16, 2006 04:04 AM
sdfollmer
Nov 13, 2005 09:11 PM
