94 AC Problem
Old Sep 10, 2012 | 12:49 PM
mwilliams275's Avatar
Default 94 AC Problem
About two weeks ago in my 94' honda accord my ac just stopped blowing. The fan that is in front of the driver has also stopped working. I tried to see if my heat would blow and it also does not blow at all. I was wanting to know what y'all think could be the problem?
Old Sep 10, 2012 | 05:37 PM
I moved this for better answers.
Sounds like it might be a fuse.
So is the blower motor spinning at all in any setting? This doesn't mean it is bad, just trying to back into where the issue might be.
Old Sep 10, 2012 | 06:16 PM
A failed blower motor will disable AC. Check for 12V to the fan connector. If you have 12v, the blower motor has failed.
Also if only one cooling fan is running, that fan, fan relay, or fuse is faulty.
Old Sep 10, 2012 | 08:00 PM
Does the blower inside the car work on the highest speed setting (4 I think)?
Old Sep 11, 2012 | 12:49 PM
No not in any setting not even when I turn the heat on.
Old Sep 11, 2012 | 12:51 PM
No it does not but sometimes I will feel cold air coming out the vent but not blowing and not for long.
trouble
Aug 21, 2012 07:46 PM
jkrueger2020
Mar 10, 2011 02:18 AM
kellysa111
May 1, 2009 08:35 AM
mahones
Oct 13, 2008 08:24 AM
92Inspire
Aug 13, 2006 03:37 PM
