94 Accord A/C after repairs still not working
Old Aug 20, 2012 | 09:01 PM
skimom33's Avatar
Default 94 Accord A/C after repairs still not working
Replaced the drier/regulator and the valve, BOTH.
The A/C ran AWESOME! Cold down to 40degrees or so.
Turned off the car and it sat til the next day.
Now it pumps out heat at 100+ degrees.
What else could be wrong with it????
Fans are running PERFECTLY. It all ACTS like it is working perfectly, but there is DEFINITELY something wrong somewhere.
Would it be easier to just take it to a repair guy and have them professionally diagnose the problem? Is there a code from the computer that will tell me what it is? Id rather not spend the money, but, it is what it is, I suppose.
Old Aug 20, 2012 | 10:03 PM
What are the pressure readings?
Is the compressor coming on?
Old Aug 21, 2012 | 12:15 AM
skimom33's Avatar
70 on both
And yes, everything is working properly, as far as we can tell.
But, obviously, nothing is actually moving around.
So I'm not sure if there is something plugging the tubing or if something broke loose in the compressor and is once again blocking the valves or the drier, or what?
Old Aug 21, 2012 | 04:47 AM
my1st.honda93's Avatar
i got a little confused when you said nothing is moving around?but if it is blowing air mite wana check the refrigerant?
The sight glass on top of the receiver-driver,if it looks foamy its low if you see nothing its empty!
Old Aug 21, 2012 | 05:57 AM
Hi probability you have a leak that was never fixed. Low refrigerant is most likely reason for loss of cooling so quickly.
A good auto ac shop will perform a leak inspection to indentify leak points for $50-$100. Leaks in evaporator expansion valve and feedback bulb are highly likely w/ an older system.
Old Aug 21, 2012 | 01:17 PM
skimom33's Avatar
No leaks. Like I said, everthing SEEMS to be running perfectly, but no cold air.
I guess I have to spend the big bucks taking it to a shop, or just buy a new compressor and condensor. Oh well.
Old Aug 21, 2012 | 02:21 PM
skimom33's Avatar
Oh, and a leak test was performed. It was evacuated and pressure tested and evac'd two or three seperate times, plus he flushed it when he initially took it apart to replace the drier and expansion valve. And it all held fine... and R134 when evac'd and replaced was the same amount. ugh!
Old Aug 21, 2012 | 03:37 PM
Well if if all is working fine and there is no leaks and the refrigerant is full? this is what i believe it could be,try and stay with me on this,
The blower fan forces the warmer air of the passenger compartment through the evaporator core transferring the heat from the air to the refrigerant.The liquid refrigerant boils off into low pressure vapor,taking the heat with it when it leaves the evap.
Old Aug 21, 2012 | 06:09 PM
You should be getting cooling if the compressor is turning (clutch plate on face of compressor closes and turns w/ pulley drive). If this isn't turning, the clutch gap may be too large.
If clutch plate is turning w/ no cooling, check that heater control valve is closed.
Only other reason no cooling and compressor running would be defective expansion valve; either wide open or too closed.
Most of above can be done w/o gauges. If you have a sight glass, please inspect for bubbles or clear liquid flow.
Jacob305
May 22, 2013 07:50 PM
powerslave
Jul 31, 2012 03:09 PM
KaboomCult
Jul 7, 2012 10:58 AM
HondaAccordEX94
Dec 18, 2009 09:43 PM
anneinct
Jun 6, 2009 10:23 PM
