94 Accord - Climate Control Air Vent Switch
Old Sep 16, 2015 | 12:35 AM
matthew042's Avatar
Default 94 Accord - Climate Control Air Vent Switch
1994 Honda Accord EX, 2.2L VTEC, 251K Mileage
On the climate control system of my Accord, everything works except for two things.
1. The "Face only" vent does not work at all, though the LED light above shines green.
2. The windshield only vent works, but the LED orange light above the button is intermittent - it sometimes comes on/sometimes does not depending on how hard I hit the button.
All other air vent modes work, so I am thinking of crossing out the mode control motor as a culprit.
Could it be the control panel of the air vent modes that needs troubleshooting? Secondly, if it is the control panel, would it be something I can open up and re-solder joints on the circuit board?
Old Sep 16, 2015 | 12:09 PM
travrach's Avatar
See this Bulletin, sounds like the issue. If you can solder, I'd take it apart
Model
1994-95
ACCORD
File Under
ELECTRICAL
Bulletin No.
95018
Issue Date
MAR 20, 1995
Heater Control Panel Indicators Do Not Light
SYMPTOM
The indicator light does not come on when its associated button on the heater control panel is pushed.
PROBABLE CAUSE
The heater control panel circuit board has fractured solder joints.
Old Sep 17, 2015 | 03:39 PM
matthew042's Avatar
Re-soldering the joints on the mode switches and LEDs did the trick.
I followed the manual guide to check for continuity on the circuit board, and reinstalling was a breeze.
Thanks travrach!
Attached Thumbnails 94 Accord - Climate Control Air Vent Switch-screenshot-2015-09-17-13.38.10.png
Old Sep 17, 2015 | 03:56 PM
travrach's Avatar
Nice job!
nccame2
Mar 31, 2014 02:44 AM
loadder
Sep 13, 2012 06:22 AM
00AccordLX5spd
Feb 17, 2008 03:14 PM
greenbean
Sep 21, 2007 03:14 PM
scarlin
Dec 9, 2006 05:07 PM
