94 Accord Door Actuators
Old Jul 22, 2007 | 11:31 PM
Pogigreg
Default 94 Accord Door Actuators
The door actuator on the rear passenger door makes a loud grinding noise when I lock it. I believe this is a sign that the actuator will eventually give out. I've been going to the junk yard studying other similar Accords, and is it the three screws in the side of the door by the latch that is the actuator? It seems as if the door latch and the actuator are one assembly. Is this the case? How do I remove and replace it?
Old Jul 23, 2007 | 12:06 PM
hondadude's Avatar
Default RE: 94 Accord Door Actuators
Latch and Actuator are 2 different parts, the actuator is held on to the latchwith 3 tiny phillips head screws. With the innerdoor panel off there is no need to remove the latch
The actuator has a plastic tab inside it that retains a spring, the tab breaks loose, but you can fix it with epoxy and a stack of a"shims".
MessAround
Jul 28, 2012 05:15 PM
tomtom
Aug 28, 2010 11:33 PM
tomtom
Aug 25, 2010 01:04 AM
proxybox
Oct 5, 2009 12:39 PM
WhyNotFab
Sep 22, 2006 03:29 PM
