94 accord ex f22b1 manual won't rev passed 4800rpm???
Old Aug 17, 2010 | 11:56 PM
mdowen's Avatar
Default 94 accord ex f22b1 manual won't rev passed 4800rpm???
I just bought a 1994 honda accord ex with the f22b1 motor with a 5 speed tranny, the car runs good but won't rev passed 4800 rpm.............it's like a rev limit kicks in, then the check engine light came on and it won't rev passed 3800,,,,,,,,,,,,i'm new here guys.....and i'm lost. PLEASE HELP!!!
Old Aug 18, 2010 | 03:31 AM
The check engine light turning on means that the engine computer detected a problem and stored a code to help identify the problem.
Follow this procedure: http://www.dhost.info/accordinfo/howto/cel.html
Post the code(s) that flash on here.
Old Aug 18, 2010 | 04:31 PM
mdowen's Avatar
I got code 21 vtec spool solenoid valve and code 22 vtec pressure valve.
Old Aug 18, 2010 | 04:55 PM
Check that you have enough oil in the engine at the dipstick.
I would check that the connections on the vtec solenoid and pressure switch are tight. Also look for signs of oil leaking around it. Clean any oil out of the electrical connector.
In the DIY section, I posted a spooner link in the Online Manuals thread. There is a 94 accord shop manual that you can download. There are some tests that you can do with a volt meter on page 6-4 and 6-6 for the code 21 and 22. You will not easily be able to do the tests where it calls for the test harness plugged into the wire harness and the ECU, since you do not have that. You can get through most of the tests though.
Old Mar 16, 2012 | 01:20 PM
jknichols20's Avatar
i have the same car and mine wont rev over 4800 but i have never gotten a check engine light... i have tried everything
aloha_bruddah
May 10, 2014 05:19 AM
argarcia86
Mar 17, 2013 08:28 PM
elmerochingon
Oct 25, 2012 10:21 PM
Slidesquad240
Sep 29, 2012 09:29 AM
skinnytexan
Oct 17, 2009 08:21 PM
