94 Accord losing oil
Old Mar 12, 2013 | 02:13 AM
  #21
Pavel's Avatar
Ok, did some hill runs, a trail of blue smoke is visible under really heavy acceleration.
So that condemns the rings to letting oil into the chamber but how much exactly is my question.
I find it surprising this much oil can go into the chamber and the car still run...
Old Mar 12, 2013 | 05:56 AM
  #22
shipo's Avatar
The old adage says, blue smoke when going up, rings, blue smoke when going down, valve guides.
Old Mar 12, 2013 | 06:52 AM
  #23
Pavel's Avatar
That's a fair conclusion.
Time to scrap the engine I guess, without a definite answer where a liter of oil is going every 100 kms.
Old Mar 13, 2013 | 03:30 AM
  #24
Pavel's Avatar
Update on the situation.
Noticed a huge oil leak coming from the central part of the engine.
I can only reproduced it after a long drive, when parking and moving back and forth.
a spot of oil the size of a CD suddenly comes out.
Old Mar 13, 2013 | 10:34 AM
  #25
It would be good to pinpoint where it's coming from.
Old Mar 13, 2013 | 12:06 PM
  #26
Oil filter and oil pressure switch are on back side of engine. Oil Pressure Switch is a known leak source. Can be a large leak.
Valve cover can leak to back side of engine but trail from cover downward should be obvious.
Old Mar 14, 2013 | 04:21 AM
  #27
Pavel's Avatar
Leaks are one thing, but their causes are different.
I've noticed some steam from the dipstick and valve cover breather.
It could be excessive blowby pushing oil past seals no?
Old Mar 14, 2013 | 07:36 AM
  #28
Another common thing is a bad PCV valve allowing the crankcase to pressurize.
Old Mar 14, 2013 | 11:07 AM
  #29
Hamster108's Avatar
take the oil cap off, and gun the motor. If there is oil shooting out your rings are toast.
Old Mar 15, 2013 | 04:17 AM
  #30
Pavel's Avatar
Car is sold.
Thread can be closed. Thanks guys!
triplej
Sep 28, 2010 08:11 PM
ekimshaff
Apr 28, 2010 04:22 PM
Greg97
Jul 14, 2008 09:32 PM
PLN595
Feb 23, 2008 02:00 PM
ulnv4ever
Nov 6, 2007 06:49 PM
