94 Accord LX AC Blows Warm
Old May 10, 2016 | 07:38 PM
Ryoku92's Avatar
I managed to fix the drivers side condenser fan, theres a red wire on the lower part of it and underneath it theres a plug, but nothing was attached to it.
So I took a plug I had found lying around in the engine bay, slipped that narrow metal plug into it, plugged it in, and now both fans run when I turn on the AC.
Only issue is that the AC itself still does not work, I will run more tests and see whats going on with that (and I will make note of the wire colors). I'd rather not try hot-wiring the compressor though, that could cause issues if I run it for too long.
Old May 23, 2016 | 03:09 PM
Ryoku92's Avatar
Default 94 Accord LX AC Blows Warm
So the fans are back online, I took the car to a shop and they couldnt get the compressor to turn on (even through hot wiring it), it'd receive power but it wouldnt rotate.
Is the compressor shot or could this be something electrical? When the AC quit on me I did hear some...unpleasant noise of debris in that area.
EDIT: Turns out my fans no longer come on when the AC is pressed, fuses are fine and switching relays makes no difference. Seems whatever "hot wiring" happened screwed something up. Radiator fan still works when you turn the car off.
Old May 23, 2016 | 08:49 PM
Copied your update post to this thread, so we can know what you are talking about. It is hard to remember what you already tried without the prior advice/tests.
Can you use your volt meter to tell us if the fans and the compressor are getting power when you turn on the a/c? It is difficult to give advice without this information.
mshondafrustrated
Oct 27, 2015 10:35 AM
4x4aholic
Nov 3, 2013 06:26 AM
Cbr1000f
Jun 21, 2013 02:46 PM
MHFry1
Jun 18, 2013 05:46 PM
JohnDanese
Apr 16, 2009 10:10 AM
