94 Accord LX - blower only works on high
Old Oct 28, 2011 | 09:26 PM
njjoe's Avatar
Default 94 Accord LX - blower only works on high
The blower only works on high. Are there some fuses, resistors that control the lower speeds that I should replace? Have others found the control know to be the problem? Do you think it's the motor itself? Again, motor works fine but only on the highest setting.
Thanks
Old Oct 28, 2011 | 09:44 PM
njjoe's Avatar
Default Blower on high
From what I searched on the forum, it seems like the resister is more likely the cause. Where is this resistor located and is there a test that I can do on the resistor to prove it is the problem?
Old Oct 28, 2011 | 09:45 PM
Sound like blower motor resistor. If you have a multimeter or ohm meter, you can test the resistance. But, even without testing, usually it will be the resistor.
Attached Thumbnails 94 Accord LX - blower only works on high-blower-resistor-testing.jpg   94 Accord LX - blower only works on high-blower-resistor.jpg
Old Oct 30, 2011 | 10:54 AM
njjoe's Avatar
Default Blower Motoe Resistor now fixed
Thank you all. This was a quick fix, the old one tested bad on my ohm meter, purchased a replacement and bingo - all 4 speeds on the blower motor work again.
Thanks.
JOE.G
Jan 1, 2015 05:48 AM
jlpatterson
Dec 9, 2013 06:25 PM
smitty2919
Dec 16, 2012 10:21 AM
VAaccord
Nov 14, 2010 09:29 PM
d_c_voss@yahoo.com
Jul 14, 2008 03:06 PM
