94 A/C replacement...con't!
Old Feb 5, 2014 | 06:13 AM
skimom33's Avatar
Default 94 A/C replacement...con't!
Last summer, I replaced EVERYTHING on my A/C in my 94 Accord LX. I THOUGHT I had everything accounted for...until... I was recharging the system and another issue arose!
The safety valve is clearly damaged and the new compressor I installed did not come with that manifold (for lack of a better term) that installs on top of the compressor.
I can't seem to find one anywhere on ebay. Does anyone know what that part is called so I can more readily search for the replacement???
Thank you!
Dawn
Old Feb 5, 2014 | 08:35 AM
Item is called relief valve. It releases when pressure is extremely high to protect against explosion. It release at over 400 psi.
You should be able to purchase a replacement relief valve from an AC supply store or auto parts store. Otherwise, you may have to purchase an entire used compressor to get one.
Note, there is an oring seal beneath the valve. Is leak coming through valve or around valve?
Old Feb 5, 2014 | 10:14 PM
skimom33's Avatar
After I almost finish filling the system with the first bottle and it all looks good and the numbers are doing great the relief valve starts squirting. I even did it with a seasoned mechanic showing me how to do it properly and he didnt know for sure what Honda manufacturing calls that part.
Old Feb 5, 2014 | 10:24 PM
skimom33's Avatar
BTW - Hondapartsnow.com calls it a service suction valve... but Honda has no idea what Im talking about.
Old Feb 6, 2014 | 08:28 AM
You need to go to junk yard, an auto parts or auto AC supply store, or try to call following guys for parts, ackits.com.
iaind
Jul 30, 2010 09:24 AM
kellysa111
Jul 12, 2009 06:10 PM
bruffy
Nov 17, 2008 02:35 PM
spliffy
Jul 29, 2008 05:31 PM
ckebottle
Apr 18, 2007 11:41 PM
