94 high idle problem
Old Apr 4, 2010 | 04:06 PM
link182's Avatar
Default 94 high idle problem
I have been seaching the forum for about 3 days now gathering all the info I can about my problem. Before I attempt any of the proposed fixes I just have a few questions. Ok my 1994 Accord coupe idles at 3000 RPM's. We unplugged the map sensor and the car idles at 1200 RPM's. So here is my question: should I spend the money to replace the map sensor, or is it another problem?
Old Apr 4, 2010 | 07:06 PM
styles's Avatar
well I don't understand it idles when the car is not moving. Doest do it by it self. Cause if that is the problem, I had the same problem with my 94 accord. Come to find put was the distributer. If u car idles by itself u should change the distributer. This cars tends to do this when the distributer is about to die.
Old Apr 4, 2010 | 07:47 PM
link182's Avatar
it idles like that as soon as you start it up. and when you depress the clutch while you are driving,.
Old Apr 5, 2010 | 08:09 AM
styles's Avatar
yeah, and goes up and down.. let me ask you a question, when its idling with out u pressing the gas, does your check engine comes on. if it does, is the distributor. so take it to your mechanic asap, other wise you can have a bigger problem. it should cost you around 100 dollars to 150, it shouldnt cost you more than that..
Old Apr 5, 2010 | 08:49 AM
link182's Avatar
Acctually it just holds steady at 3000 and I get no check engine light. But thanks for the help. Its just another thing Ill have to give consideration to while diagnosing the problem.
Old Apr 5, 2010 | 08:37 PM
I think I've put something in the DIY section about setting your BASE idle. Try that.
awschubert
Apr 4, 2013 05:43 PM
90pioneer
Apr 9, 2012 09:06 PM
MICHOASTYLE
Mar 15, 2012 06:16 PM
jimcmiller
Apr 5, 2010 08:54 PM
PaulV17
Oct 1, 2008 01:07 PM
