94 Honda Accord crank pulley come loose with the nut tight
Old May 10, 2012 | 07:09 PM
Doug Grellner's Avatar
Default 94 Honda Accord crank pulley come loose with the nut tight
Got a 94 Honda Accord with a 4 cylinder engine in it , today all the belts flew off - started checking it out and the crank pulley was wobbling bad - the bolt holding it on is tight , but the crank pulley hole seems wore - i guess i need a new pulley ??? Is this a common problem on these ???
Old May 10, 2012 | 07:58 PM
It's not too common; but, the crank pulley aka harmonic balancer pulley does sometimes needs to be replaced. It has rubber dampening material near the center of the pulley. Some people think it's all metal; but, it's not. It just looks like it's all metal because it is black.
When I use to have a 1995 Accord, the crank pulley started going bad and I had to replace it. On mines the wobble caused the pulley to start cutting into the plastic timing belt cover. That was many years ago.
Old May 10, 2012 | 08:48 PM
crispin's Avatar
I saw someone replace their motor because of that. They insisted that the end of the crank was bad.
Old May 10, 2012 | 08:51 PM
Daily Cruiser's Avatar
^^ lol
Old May 10, 2012 | 11:48 PM
deserthonda's Avatar
seen it happen more than ones ,, get 1 at a salvage yard,,,,,,,,
Old May 11, 2012 | 04:25 AM
The rubber materials good , just the hole in the dampeners bad
Old May 11, 2012 | 11:25 PM
The hole for the crankshaft? It's just a hole. Is the square key (#24) missing?
Old May 12, 2012 | 12:17 AM
Unless he removed the bolt he cannot see if the key is there ......
have you removed the crank bolt and the pulley and chk it for damage??
tashier
Mar 19, 2018 08:13 AM
KimHutcheson
Oct 9, 2014 02:19 PM
jmattick
Jan 25, 2011 06:37 PM
kegwad
Jun 22, 2009 09:20 AM
nrangerfan
May 20, 2005 01:57 AM
