94 Honda Accord lx
Old Apr 2, 2020 | 06:10 PM
Karl Graves's Avatar
Default 94 Honda Accord lx
What dose ignition output mean it's what came up on code
Old Apr 2, 2020 | 06:19 PM
Seanjordan20's Avatar
What code are you actually getting
I would start troubleshooting at the distributor. Wires, cap and ignitor possibly the distributor as a whole.
Old Apr 2, 2020 | 07:06 PM
Thanks I will try it I'm getting a 15
Old Apr 2, 2020 | 07:30 PM
Ok was just making sure it was the code I was thinking it was
Old Apr 2, 2020 | 09:13 PM
Is the car not running?
A code 15 is an issue with the ignition control module circuit. This is also known as the igniter.
Technically the problem can be with the igniter, electrical/wiring, the coil, or the ECU.
The most likely culprit is the igniter, but I would remove the distributor cap (keep the spark plug wires attached, so you don't mess up the firing order). Look for any obvious corrosion on the connections to the igniter.
donjuanlucas01
Feb 17, 2013 09:10 PM
Mdschmidt
Sep 9, 2009 06:07 PM
iniguy
Sep 8, 2009 08:27 AM
dmlagrange
Oct 2, 2008 07:20 PM
papaschilling
Jan 25, 2008 11:56 AM
