94 Transmission problems
Old Mar 5, 2013 | 10:27 PM
Cali94Accord's Avatar
Default 94 Transmission problems
Hey all, so just recently I was driving on the freeway and my car wouldn't stay in 5th gear AT ALL! Very annoying.. I've never been one to drive my car hard, and I've done alot of research but no difinitive answers yet. So here's what I've found; could be the tranny, tranny fluid, synchros, or shift linkage...
If anyone has any advice or better knowledge than myself please let me know.
( hopefully it's not the tranny)
Old Mar 6, 2013 | 05:29 PM
Did you notice anything strange with the D4 light? Wouldn't hurt to check for codes, on this car all you need is a paperclip to jump the service connector to chaeck for codes.
Anything recent done to the car?
Yes check the fluid, if you are not sure when it was last changed I would suggest at least one drain and fill with Honda Fluid....if it gets better than two more drain and fills.
Old Mar 7, 2013 | 06:32 AM
Manual transmission....
Unless it's a manual swapped into an automatic car, there is no D4 lamp.
I've heard of popping out of gear because of mis-adjusted shift linkage, for the most part it comes down to the transmission isn't "all the way in" to 5th even tho the shift lever is all the way forwards.
I guess look at the shift cable connections? I haven't had them apart on an Accord, so can't be very specific. Loose bushings where the cable attaches to the lever at either end of the cable? Something in the console blocking the lever from going all the way forward when you shift into 5th?
Fluid change sure won't hurt, how long has it been?
Maybe a worst-case would be bent shift-fork inside the trans?
Old Mar 7, 2013 | 07:52 PM
That was bad ....5th gear and I thought is was an auto trans. Wow.
OP - Sorry about that.
Old Mar 19, 2013 | 10:23 PM
96hondaaccordlx91190's Avatar
for f22 engines are all transmissions the same I just bought a new one for my 96 accord the only thing different on it is the shift solinoids does that make a difference?
Old Mar 19, 2013 | 11:35 PM
Hamster108's Avatar
if you are low on fluid, 5th will pop out. Check that **** first.
dzimmerman1977
Nov 15, 2006 07:10 PM
YeuEmMaiMai
Sep 4, 2006 10:27 PM
KimberlyC
Apr 16, 2006 11:51 AM
monroe
Oct 24, 2005 10:22 AM
darkstar05
Apr 13, 2005 10:13 PM
