95 Accord 4 cyl loose crank pulley bolt
Old May 1, 2016 | 09:05 AM
turbofrank's Avatar
Default 95 Accord 4 cyl loose crank pulley bolt
270k on odometer two weeks while parking car at home I heard a rattling noise simular to a loose cat shield. My first thought ps pump disconnected belt noise still there. While thinking whats next alt belt comes off. At this point i notice pulley wobbling. loose bolt previous owner replaced timing belt i suspect bolt not tightened to specs . After buying new belts, crank holding tool and tightening bolt to correct specs 181 ft lb iam back on the road. lucky it didn't happen on highway or far away from home.
Attached Thumbnails 95 Accord 4 cyl loose  crank pulley bolt-img_20160419_105238_zpszqhkd6ad.jpg   95 Accord 4 cyl loose  crank pulley bolt-img_20160419_111026_zpssnlar6az.jpg   95 Accord 4 cyl loose  crank pulley bolt-img_20160419_111107_zpsvucfxhki.jpg   95 Accord 4 cyl loose  crank pulley bolt-img_20160419_111527_zps7wcw5eyq.jpg
Old May 1, 2016 | 11:03 AM
Yea, sometimes being lucky is all that counts
I would re-check it in a week or so just to be sure it is staying tight.
KimHutcheson
Oct 9, 2014 02:19 PM
SirJohnIII
Oct 7, 2014 09:46 PM
Doug Grellner
May 12, 2012 12:17 AM
swordfish7769
Nov 21, 2008 10:44 PM
ckebottle
Nov 22, 2007 03:01 PM
