95 accord ex no lock up after rebuild
Old Mar 1, 2011 | 06:53 PM
motleyman's Avatar
ok,after checking everything according to the book,I came up with the tps not working properly,is there an easy fix,do i really have to replace the intake plantum,i found a tps for less than $50 new,wht should i do,the plantum is $600
Old Mar 1, 2011 | 08:29 PM
Couple of choices, a used tb-should be less than the 600 or replace the tps. If you are good with a DVM-which I'm sure you are- then you should be able to install a new one and get the adjustments correct....don't quote me but I think it is .5 at idle and 4.5v at WOT. EDIT: again use the manual for proper settings
What test "failed" the TPS?
Old Mar 1, 2011 | 09:37 PM
motleyman's Avatar
yes,the tps failed
Old Mar 8, 2011 | 07:57 PM
motleyman's Avatar
ok,thought i read the volt meter right,after goin back and retesting,if i test the way the book says and probe the yellow with blue wire and the green with blue wire,which is the 1 and 3 pins,i get 4.5 volts at both open and closed throttle,if i follow the directions of the new tps,which tells me to probe the 2 and 3 pins,i get 4.5 volts at closed throttle and .5 at open throttle,according to both the new directions and the book,it should read the opposite,now what,where do i go from here
Old Mar 9, 2011 | 06:25 PM
According to the book/manaul I have that is only the first part of the test. Part two-after the @5v at the Yel/Blu and Grn/Blu-From there, re-connect the tps, at the ECU check the voltage between D11 (+) and D22(-) for @4.5v at WOT and @.5v at closed. Then another decision tree depending on the results.
Old Mar 9, 2011 | 08:16 PM
motleyman's Avatar
ok,i will try that tomorrow and get back to you,thank you
KaOS311
Mar 9, 2014 09:45 PM
tap500
Dec 3, 2013 06:16 PM
armmata
Oct 15, 2013 03:05 PM
lgrouper03
Dec 24, 2011 08:21 AM
jsparks
Dec 23, 2011 12:22 PM
