95 Accord EX starting problems
Old Jul 19, 2011 | 03:24 PM
don_honda's Avatar
I checked and the ECM does recive battery voltage from the ICM, ¿could it be the coil or the ecm? i just dont wanna guess since ignition parts are kind of expesive and then it turns out it's the ECM and it's impossible to get a working ecm or dizzy here to try...
Old Jul 19, 2011 | 05:55 PM
How did you hook up the test light?
Old Jul 19, 2011 | 07:11 PM
Tek310's Avatar
if the ignitor flashes during cranking, your coil is bad. if it did not flash your ignitor would be at fault.
Old Jul 20, 2011 | 02:08 PM
don_honda's Avatar
the tip to the blue wire from ignitor to coil, and the clamp to the battery +
Old Jul 20, 2011 | 02:18 PM
don_honda's Avatar
Since yesterday the car is starting just fine, today morning it started nice again, need to say that it has't rain this days and is so less humid (the car stays outdoors), when I removed the dizzy cap two weeks ago when he car started failing (very rainy cold and humid days) I found the cap seal dry and broken, ¿is it possible that the coil stoped working due damp inside the distributor? i'm repacing today the cap and the seals, and the wires... will let you know. if it keeps failing will replace the coil.
Guys, I really apreciate your help, thank you very much both of you. I'm really happy to own a honda
Old Jun 3, 2012 | 02:27 PM
Andy2012's Avatar
Has anyone's problem been solved yet? I have already gone through everthing on this post. I am working on a friends 98 honda accord 2 door coupe.
Old Jun 3, 2012 | 03:30 PM
  #17
crispin's Avatar
Originally Posted by don_honda
Since yesterday the car is starting just fine, today morning it started nice again, need to say that it has't rain this days and is so less humid (the car stays outdoors), when I removed the dizzy cap two weeks ago when he car started failing (very rainy cold and humid days) I found the cap seal dry and broken, is it possible that the coil stoped working due damp inside the distributor? i'm repacing today the cap and the seals, and the wires... will let you know. if it keeps failing will replace the coil.
Looks like it to me
MRMASON
Oct 3, 2006 07:15 PM
masteve69
Aug 20, 2006 04:58 PM
applewart
Aug 9, 2006 03:07 AM
hofmeister
May 26, 2006 09:11 AM
KimberlyC
Apr 16, 2006 11:51 AM
