95 Accord need some help
Old Feb 3, 2016 | 05:44 PM
sulliuno's Avatar
I went off the rpm marks that are on the gauge. Just to give you a background on me ( I know you were not bashing) I am no stranger to auto repairs I am a master gmc tech but since I swapped jobs I don't have all my dio tools and I am not amazingly well versed in honda systems... I did clean both sides of the plate as well as the holes that feed the iac valve... checked and the coolant hoses were not blocked.. air filter is not clogged... I did remove the front Plate on the fitv and found the plastic nut tight no excessive carbon buildup etc
Old Feb 3, 2016 | 06:31 PM
Thanks for the background. The tachometer marks can be confusing if you look at how Honda skipped 250 after 0 rpm.
The low idle at startup is what I'd start diagnosing. If you take the snorkel off the throttle body, one hole is the bypass for the IAC and the second hole is the bypass for the FITV. When the engine is cold, cover the lower (FITV) port with your finger. Does the idle change and does that port have a strong vacuum?
If you can read fuel trims live, you can figure out if you are running rich or lean when you start getting the misfires via the obd2 port.
Old Feb 3, 2016 | 06:32 PM
sulliuno's Avatar
If I can get it to idle the lower hole has good vacuum and stalls engine if I cover it fully
Old Feb 4, 2016 | 11:17 AM
You found the OBD-2 port & said there's no codes. But what about the fuel trims?
Old Feb 4, 2016 | 12:24 PM
sulliuno's Avatar
The fuel trim is normal when warm long term is a little rich but as it runs it goes to normal
cg31998
Dec 14, 2010 08:46 AM
inmate1981
Oct 1, 2009 10:10 AM
a94060
Jun 6, 2009 09:45 PM
JeffreyMill91
May 8, 2008 02:52 PM
bigZ
May 18, 2007 12:35 AM
